It is currently Thu Nov 21, 2024 9:10 am
[ 6 posts ] |
TOOLMAN
(2) Bilstein 5125
Two Bilstein 5125's. I initially used these up front for one season (probably 1000 miles with one wheeling trip) and switched up because they were a little too soft. I thought I could use them in the back, but they're a little too long. Here's the particulars:
Model 33-104652 (WH #BIL88118) Collapsed: 17 Extended: 28 Travel: 11 Valve: 255/70
$125
Fri May 15, 2020 4:15 pm |
Re: (2) Bilstein 5125
What lift are you running?
Wildhorses says they are for rears for 2"-4" lift. I'd be interested if that is what they fit.
Fri May 15, 2020 4:24 pm |
TOOLMAN
I'm running 3-1/2" lift with stock mounts. I just got off the phone with them and that's a typo. The 88116 is the correct one for 2-4" lift and stock mounts. These might work if you're running a modified shock mount setup and need a bit more shock. My mount to mount measurement is 19-1/2" so these would only leave me with 2-1/2" of compression. With the shocks I have now I have 4-1/2" compression.
Fri May 15, 2020 4:39 pm |
Fri May 15, 2020 4:51 pm |
TOOLMAN
Yeah, if you're going to run used springs your distance is probably even smaller than mine. I have pretty new HD 11 pack Deavers from Duff, but I'm also running a 200 lb. bumper with a 23 gallon tank.
Fri May 15, 2020 4:57 pm |
The springs aren't that old, I had replaced them just a couple years before the 74 was parked and went under the knife. But I have no idea how things will sit. I just measured the shocks with the current lift (about 3.5") and I've only got 20.5", it's close but I'm probably better off waiting till I can get measurements with the newer springs.
Fri May 15, 2020 5:18 pm |
[ 6 posts ] |
