www.ColoradoClassicBroncos.com - View topic - Upgraded steering
It is currently Thu Nov 21, 2024 11:51 pm
Reply to topic  [ 12 posts ]
 Upgraded steering
Post Upgraded steering
Don’t think it’s time to update my steering. After years of my 35’s I think the tie rods are about ready to give up. What’s the best bang for your buck? Ruff stuff, duffs, toms, etc. I am a little confused with the ruff stuff as most of there kits come with a flat top knuckle conversion but I am not cool enough for that yet.
Wed Aug 19, 2020 2:24 pm
Post Re: Upgraded steering
Here's what I'd suggest:
viewtopic.php?f=32&t=963&hilit=heavy+duty+tie+rod
And you are definitely cool enough for a tie rod over swap. If you do it, you'll need to correct your track bar alignment, but there's a couple easy ways to do that.
Wed Aug 19, 2020 7:32 pm
I did this one...
Relatively affordable. In the long run, I can change out the ends and go over knuckle.
Wed Aug 19, 2020 10:29 pm
I did the Ruff Stuff. I like it. If you have stock knuckles and you don't want to do much work, i like the Wild Horses setups.
Thu Aug 20, 2020 7:11 am
If you go ruffstuff get the “problem solver” it helps prevent the roll over & dead feel in the middle of the steering.
Thu Aug 20, 2020 10:45 am
Fri Aug 21, 2020 6:34 pm
Yes, you are looking for "The Cure". I also read about installing the tie rods with the tie rod ends rotated back so the drag link drops down through the tie rod end, more than from front to back (or something like that). This takes some of the 'slack' out when you have the steering centered. I can't find where I read that, hopefully someone can chime in and confirm that I'm recalling this correctly.
Fri Aug 21, 2020 7:15 pm
Here is where I read the info on the tie rod/drag link positioning. It's my thread on the death wobble that started my never ending upgrade:
viewtopic.php?f=5&t=6734&hilit=rotate+drag+link
Fri Aug 21, 2020 7:29 pm
Sat Aug 22, 2020 3:17 pm
So do I need two? One each for the top and bottom of the drag link?
Sat Aug 22, 2020 4:12 pm
Sat Aug 22, 2020 4:43 pm
You just need one. It replaces the boot on the drag link at the tie rod intersection. It basically seats the drag link end and holds it in place so that it doesn’t flop around the boot as much. You will have to be diligent to keep that end greased. I ran one for a while on my red bronco. It helped but so does setting the links up correctly so the leverage doesn’t push or pull (flop) the drag link too much.
Sun Aug 23, 2020 9:17 am
32,934,884 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
