It is currently Sun Nov 24, 2024 11:07 am
[ 15 posts ] |
RTV sustainability
You know the stuff: It's not that I hate it, but what I hate is buying a new tube for a project and using 2%, then the stuff in the neck dries when you need it again. You have to dig it out to get back to useable RTV. That usually only works once or twice. Any solutions to this? I wouldn't mind if you could buy 1oz tubes and expect to throw it away after each project. But at $7 for a 3oz tube, it sucks throwing the tube away after using only 30% of the RTV and wasting the time to dig out the dried stuff each time. Someone has to have an ingenious way to save it!?!?
Tue Aug 25, 2020 3:07 pm |
BroncoRaider
Re: RTV sustainability
You could always start more projects...
Tue Aug 25, 2020 3:48 pm |
LOL! Great logic! If only I had the time.
Tue Aug 25, 2020 3:53 pm |
Maybe take off the extended neck and put the short cap back on the tube when you're done with it.
Tue Aug 25, 2020 3:54 pm |
Tue Aug 25, 2020 3:55 pm |
ask around a bit.................I always just use a little more than necessary which seems to solve that problem
Tue Aug 25, 2020 9:17 pm |
RTV sustainability
There is a version that is loaded into a shortened caulking gun. I throw a piece of tape and cap on it and reuse as needed. I’ll look for a pic.
Thu Aug 27, 2020 8:09 am |
Please! That would be awesome! Investing in a small gun may be worth it if I can use most of the tube.
Thu Aug 27, 2020 10:55 am |
Here it is, Amazon also sells it in the caulking gun. https://www.napaonline.com/en/p/PTW7652 ... ight+stuff
Thu Aug 27, 2020 8:52 pm |
Thanks! Will dig into it!
Fri Aug 28, 2020 8:47 am |
casadejohnson
Sat Aug 29, 2020 8:30 pm |
I do the same thing as Phil. No issues with it drying out.
Mon Aug 31, 2020 7:16 pm |
I have two tubes that are about 1 or 2 years old that I have caps on them and no issues
Tue Sep 01, 2020 8:20 am |
I am doing something wrong, or just not using it fast enough.
Tue Sep 01, 2020 8:24 am |
Tue Sep 01, 2020 9:19 am |
[ 15 posts ] |
Users browsing this forum: No registered users and 57 guests |
