www.ColoradoClassicBroncos.com - View topic - Shocks for Duff long arms
It is currently Sun Nov 24, 2024 10:41 am
Reply to topic  [ 17 posts ]
Post Shocks for Duff long arms
I’m having Duffs long arms installed and the shop called to tell me that I need longer shocks as the current ones are limiting maximum droop.
I forgot I would need longer shocks.
I have 4-1/2” WH springs up front and went from stock radius arms to the Duff long arms.
1) anybody happen to know how much longer of a shock I would need ?
2) any input about Duffs new MS2020 Eibach shocks ?
Thu Aug 27, 2020 9:01 pm
Post Re: Shocks for Duff long arms
I’d recommend the ones you can get delivered and installed in the next 10 days... poke
Seriously though, try the Duff Eibachs and let all of us know how they work.
Thu Aug 27, 2020 9:06 pm
So the springs aren’t limiting the travel but the shocks are? Can the shop measure the length at full droop and then also measure the length at full stuff? You could then find your shocks based on those numbers.
Thu Aug 27, 2020 9:49 pm
Fri Aug 28, 2020 5:02 am
What I would do is bring it home. Jack it up and support by the frame. pull the front springs out of it. articulate the front axle (mostly for full stuff). Get front axle at full stuff. Measure collapsed length of shock needed. Find the longest shock that can fit in that collapsed spot. Since you are not running tall shock towers you will be limited.
As for shocks I'd get something custom to finalize the ride. Go for a ride in Chris' red bronco and see for yourself. But to do that it would be best with a new shock tower and rear shock mounts. Allows you to run a 14in shock up front and a 12 or 10 in the back.
Fri Aug 28, 2020 5:58 am
If I get a chance I’ll take one off of mine and measure. I have 4.5” springs on mine with cage arms. Seems to do really well.
Fri Aug 28, 2020 6:01 am
Fri Aug 28, 2020 8:43 am
Fri Aug 28, 2020 8:47 am
Fri Aug 28, 2020 8:49 am
Glad the shop owner is helping out. I’d think you could take your measurements and get some Bilstein 5100s for under $200/pair and then after SuperCel decide what the long term solution is. Probably sell the Bilsteins for close to what you paid.
Duff might be able to also tell you what works since you have a standard lift and didn’t change the shock towers.
Fri Aug 28, 2020 8:57 am
Duffs got em packaged up and on the way
I gave him current spring and shock details and he selected the right ones with the "you didn't give the measurements so it's on you" disclaimer so I have my fingers crossed that it works out
If they are right and I like them, may keep the current set up for a bit before diving in further
thanks for the help so far guys
Fri Aug 28, 2020 10:45 am
If there not to your liking, Have Duffs bring you another set to swap at SC and have landsharks pit crew change them out Baja style.
Fri Aug 28, 2020 10:51 am
that Michael Duff slickster talked me into their new shock tower so I guess my work load just increased
https://dufftuff.com/product/long-trave ... 77-bronco/
Fri Aug 28, 2020 12:45 pm
Isn't 27 years classic?
Fri Aug 28, 2020 4:01 pm
Fri Aug 28, 2020 7:49 pm
Fri Aug 28, 2020 8:15 pm
You'll be happier spending the money once on the right shocks for your setup!
Tue Sep 01, 2020 8:29 am
Users browsing this forum: No registered users and 58 guests
32,997,680 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
