It is currently Thu Nov 21, 2024 9:01 am
[ 25 posts ] |
casadejohnson
The 74
It occured to me that my 74, which i have owned since 1990, does not have its own build thread. Since the 66 has ben in limbo for a year waiting on the vintage inlines aluminum head, the 74 has been my daily driver. We swapped the Chevy disc brakes for ford brakes a couple weeks ago and today Phil and I started doing some measuring of compession and and axle droop so we can install F250 shock towers and the bilstein 7100's that I picked up from Toolman. The current shortlist of items to take care of are: Shock towers and Bilstein install Move the rear axle back an inch New Flares New Tires Steering box rebuild Radiator replacement and minor relocation Hydroboost rebuild Power steering cooler Install leather heated mustang seats Hopefully, we can knock a few things off the list before super celebration. Sent from my SM-N975U using Tapatalk
Mon Aug 03, 2020 12:11 am |
Re: The 74
I'm curious about the h-boost rebuild. I've read conflicting recommendations about doing it yourself.
Mon Aug 03, 2020 3:39 pm |
TOOLMAN
Re: The 74
Glad I could contribute. Thanks for the cash! I might plan on mounting the F250 shock towers a tad lower than what it will look like. But I'm sure you and Phil will get it figured out how to maximize travel.
Mon Aug 03, 2020 8:27 pm |
casadejohnson
Re: The 74
Mon Aug 03, 2020 10:42 pm |
casadejohnson
Re: The 74
Mon Aug 03, 2020 10:57 pm |
Re: The 74
Tue Aug 04, 2020 9:28 am |
casadejohnson
Re: The 74
This weekend we knocked out the steering box rebuild and plumbed it through the radiators trans cooler to keep it cool. We also plasma cut out a 5/8" spacer to move the steering box out and give some much needed clearance for the upcoming radiator relocatoin. Sent from my SM-N975U using Tapatalk
Sun Aug 09, 2020 11:46 pm |
casadejohnson
Re: The 74
Fri Aug 21, 2020 6:44 pm |
Re: The 74
Purty!
Fri Aug 21, 2020 8:45 pm |
Re: The 74
Fri Aug 21, 2020 9:10 pm |
Re: The 74
Very nice!
Sun Aug 23, 2020 9:20 am |
Re: The 74
Look at you with all that fanciness! drilled rotors and bilstein's...
Mon Aug 24, 2020 12:31 pm |
TOOLMAN
Re: The 74
Looks smart!
Mon Aug 24, 2020 1:36 pm |
casadejohnson
Re: The 74
Somebody's getting new Kicks Sent from my SM-N975U using Tapatalk
Sat Aug 29, 2020 10:18 am |
casadejohnson
Re: The 74
Fresh Rubber Sent from my SM-N975U using Tapatalk
Sat Aug 29, 2020 2:46 pm |
Strike2
Re: The 74
Those are some sweet shoes you got there!
Sat Aug 29, 2020 8:09 pm |
Re: The 74
Ahh yeah!!
Mon Aug 31, 2020 8:09 am |
Re: The 74
I have those same shoes. How is the ride?
Mon Aug 31, 2020 9:45 am |
casadejohnson
Re: The 74
Mon Aug 31, 2020 5:31 pm |
CamTheRam17
Joined: Wed Aug 22, 2018 2:38 pm Posts: 64 Images: 0 Location: Eaton
Re: The 74
My buddies were going to the steel yard in the 4Runner and sent me these!!
_________________ 1973; 302; Mexican Block; Standard 3speed; lifted; 33's; Slotted mags; Bilsteins; Stroppe; Dana 44; Power Brakes; Power Steering; Cut; Retrosound
Wed Sep 02, 2020 8:39 am |
casadejohnson
Re: The 74
Wed Sep 02, 2020 9:20 pm |
casadejohnson
Re: The 74
Before and after of the conversion from the late style turn signals to the early style. Sent from my SM-N975U using Tapatalk
Sat Sep 05, 2020 7:26 pm |
Re: The 74
So much better!
Sat Sep 05, 2020 11:12 pm |
Re: The 74
Much mo betta! The way they were intended!
Sun Sep 06, 2020 9:20 am |
Re: The 74
Great comparison! Need to do this to mine!
Tue Sep 08, 2020 8:15 am |
[ 25 posts ] |
