ETA: Thread re-named. No longer a "New Member"
ETA#2: Added Table to Contents. (This thread is getting long and I keep referencing it in other threads)
Page 1: Introduction, wiring, accessory control panel
Page 2: Wiring, accessory control panel, dash, front axle gearing
Page 3: Front suspension, rear suspension
Page 4: Rear suspension, CAD work
Page 5: CAD work, rear suspension
Page 6: Fuel system, brake lines, front suspension (shocks / air bumps), exhaust, driveshafts, first drive
Page 7: Hitch, mirrors, roll cage, rear bumper, rear storage, tires
Page 8: EFI components, swing out tire carrier
Page 9: Wiper upgrade, camshaft swap, hydro-boost, EFI
Page 10: Transmission teardown, clutch hydraulic adapter, sway bar, injector swap, roll cage padding, trailer brake controller, 36-1 crank trigger, steering wheel upgrade, R2.8 Cummins swap (intro)
Page 11: Pulling 351W V8, Cummins-ZF5 adapter design / manufacture
Page 12: Diesel gauges, Cummins-ZF5 adapter machining and install, engine mounts, engine fitup
Page 13: R2.8 SEMA pictures, fuel tank mods, intercooler selection and install, hood mods, radiator install, brake and fuel plumbing
Page 14: Brake and fuel plumbing (cont.), intercooler plumbing, coolant plumbing, air filter assembly, exhaust, remote oil filter, frame mods, engine bay paint,
Page 15: Steering column, steering gear repair, engine mods, air inlet plumbing, power steering plumbing, wiring
Page 16: LED headlights, more wiring, R2.8 first start,
Hey all, I discovered this forum after making my recent purchase. I wanted to introduce myself and get a build thread going. Here is what I'm starting with:
1969 Bronco
- 351W Crate engine, forged pistons/rods, roller cam/rockers, alum heads/intake, SS valves, 650 Holley, headers, MSD distro/ignition/coil
- NP435/Dana 20, 9 inch 31 spline Currie axle ARB - Dana44 w/ ARB, 35" BFG KM2s
- Aftermarket bucket seats, Autometer gauges, Rampage softtop
I already picked up a ZF-5 and 6:1 Atlas T-case to drop in. I also have a full width HP Dana44 lined up that needs gears and a full width BB 9inch to drop in the rear. Both with ARBs and 4.56 gears.
Looking forward to getting to know everyone!
