www.ColoradoClassicBroncos.com - View topic - Help me wire up this heater please....
It is currently Fri Nov 15, 2024 7:44 am
Reply to topic  [ 10 posts ]
Post Help me wire up this heater please....
Inside there is a white and black wire which I know go to the white and black to the outlet.....but where do I attach the grounding wire? To the chassis?
Mon Dec 05, 2011 1:44 pm
Post Re: Help me wire up this heater please....
One more pic...
Mon Dec 05, 2011 1:50 pm
There should be a green screw in there somewhere. Or a brass screw with a washer on it. And if none of the above run a tek screw onto it somewhere on the chassis and wrap the ground around that.
Mon Dec 05, 2011 2:13 pm
Take a pic of it and post it so we can see.
Mon Dec 05, 2011 2:14 pm
There a ground on the external panel but I believe that is for the thermostat (to have the fan-only) option. There is also another ground on the fan-motor case, but I can't find anything inside so I think I'll just ground the chassis.
Mon Dec 05, 2011 2:40 pm
The thermostat connections.....
Mon Dec 05, 2011 2:41 pm
I think I figured it out...there is a wire from the panel that is grounded on the back side of the item that the arrow is pointing at...it's just to the chassis...I just use one of those mounting screws.
Mon Dec 05, 2011 3:01 pm
Mon Dec 05, 2011 4:25 pm
Where's Mr HVAC?
Mon Dec 05, 2011 7:24 pm
I think I got it. Just ran 45 feet of thermostat wire and hooked it up. Wed Mr. Plumbdoctor arrives to bring in the gas and vent it:)
Mon Dec 05, 2011 8:18 pm
32,883,809 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
