It is currently Fri Nov 01, 2024 11:31 am
[ 9 posts ] |
Front Disc Brake Hub question...
Hey guys, What is the difference between the hub/rotor assy. for the '76-86 VS. '95-96? Can you make them ('95-96) work, or does it have to do with the automatic electric 4x4???/size Thanks, Mike
also...on the '89-93 they come with an ABS ring, do you leave that on or tear it off if you use these? are these the same as the early ones?
Fri Apr 10, 2015 8:11 am |
Re: Front Disc Brake Hub question...
Wait, there's a year after 1977?
Fri Apr 10, 2015 4:34 pm |
Getting ready to do the Chevy Disc brake swap. (Dana 30 up front) I have both spindles, both caliper mounts. I need the calipers and Hub/Disc assembly.
Any suggestions on where to get the cheapest ones?
I want to go New as opposed to used. Thanks
Mon Apr 13, 2015 7:57 am |
I wound up buying calipers at Advance and hubs/rotors at AutoZone.
Mon Apr 13, 2015 9:46 am |
X2. Parts store is your best bet. Rebuilt is fine.
Mon Apr 13, 2015 10:38 am |
That's good enough for me, Thanks guys!
Mon Apr 13, 2015 2:42 pm |
phyler
The hub /rotor assembly is expensive brand new. I got one from Ed the Ford parts guy for $20 and it had a good rotor on it. All of the hub assemblies through the early 90's have the same part numbers when I checked. Just went through this last fall. New the assemblies were north of $100. Hope that helps. Obviously new is just simple. :)
Mon Apr 13, 2015 9:57 pm |
You might also check with Dalli in the springs.
Mon Apr 13, 2015 11:39 pm |
Awesome, Thanks!
Mon Apr 20, 2015 1:15 pm |
[ 9 posts ] |
