www.ColoradoClassicBroncos.com - View topic - D20 clutch and flywheel.
It is currently Fri Jun 21, 2024 12:01 am
Reply to topic  [ 10 posts ]
Post D20 clutch and flywheel.
I have a new clutch, pressure plate, and flywheel $150.00
Juet pulled it out so there is a little surface rust but it does not have any run time on it.
Sat Aug 24, 2013 9:16 pm
Post Re: D20 clutch and flywheel.
Hi, getting ready to put in an NP 435 tranny once I find a used adapter. Planning on putting in a new clutch at the same time. Don't know about part numbers or names but was wondering if this will work with my 302?
Bill
Sat Aug 24, 2013 10:36 pm
This came out of a 351W So it has 11" disk, 28oz-164 tooth flywheel.Should have mentioned that...
Sun Aug 25, 2013 7:51 am
Older 351s & 302s use the same setups.
Sun Aug 25, 2013 12:11 pm
1983
Sun Aug 25, 2013 4:00 pm
So it will fit? Maybe fit? Or won't fit? When I get mine out, and if you still have yours, will do a comparison.....
Sun Aug 25, 2013 9:36 pm
If you've got a 302, very good chance it will fit. If not someone will buy it. Heck, I'd pick it up if the bronco fund hadn't taken a massive beating lately.
Mon Aug 26, 2013 12:05 am
It should fit but we could match it up.
Mon Aug 26, 2013 9:43 pm
Bump
Sun Nov 17, 2013 1:19 pm
All 351w are the same as early 302's so it should fit fine, and should be the 28oz imbalance as only late 302's/ 5.0's are 50 oz imbalance
Sent from my iPhone using
Sun Dec 08, 2013 4:32 pm
30,796,613 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
