www.ColoradoClassicBroncos.com - View topic - Rox Crusher's 77 sport
It is currently Thu Nov 21, 2024 4:32 am
Reply to topic  [ 307 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11
Post Re: Rox Crusher's 77 sport
Last month I replaced the 3-1/2" rear springs with 4-1/2" to eliminate saggy ass syndrome. Turned out pretty good, it raised the rear bumper by 2" (the rear leafs must have had some sag to them).
Previously when I had 3-1/2" springs all the way around, my rig had a slight rake to the front which I attributed to the typical settling associated with WH coil springs. So I replaced them with 4-1/2" WH coils thinking they too would settle expecially with the extra weight of the winch........and ultimately the stance would be nuetral. But for some reason the fronts don't seem to have settle while the rears definitely did.
Thu Jul 01, 2021 4:15 pm
Doing some upgrades and maintenance in preparation for the upcoming Rubicon trip !
I have had a small vibration coming from the rear end and the axle keeps leaking at both ends so I replaced the bearings and seals. Looking at the used bearings you could see some slight wear on the races but it also looked like the inner races were rotating on the axles which is worrisome. Ride is much smoother now without any vibration. Hoping the new seals will solve the leaks....... we shall see.
Before replacing the wheel bearings, and thinking the vibration was from a worn driveline, I ordered a new one from Tom Woods. I needed a longer one due to the new 4-1/2" springs anyway.
Last things on my list include fixing an exhaust leak on driver's side header and installing some new Duff Eibach shocks on the rear if they arrive in time.
Other than that I am locked and loaded.
Thu Jul 01, 2021 4:33 pm
Great progress Rox. It’s cool to hear about your improvements. I have to replace the bearing and seal on pass rear and I’m a little gun shy because I understand you have to cut the old bearings off. I have a small bearing 9”. Did you cut your bearings off? How’d that go? Thanks!
72 Bronco Sport, 5.8 EFI, NV3550
Mon Jul 05, 2021 9:29 pm
Mon Jul 05, 2021 10:21 pm
Good idea. Thanks for the insight!
Mon Jul 05, 2021 10:22 pm
I've got a press. Usually just cut them most of the way and then hit them with a chisel and big hammer. Happy to help.
Thu Jul 08, 2021 5:46 pm
Justin, If I cut mine off, and bring you an axle, bearing, and a 12 pack, do you think we could press mine on? I’d feel better if a bronco guy does it, because we all care a little more. If not, I understand.
Fri Jul 09, 2021 9:37 pm
32,908,264 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
