www.ColoradoClassicBroncos.com - View topic - D20, J-pattern DIY twin stick question
It is currently Sun Nov 24, 2024 5:57 pm
Reply to topic  [ 21 posts ]
Post D20, J-pattern DIY twin stick question
One of the last original parts on my Bronco is the D20 t-case. It has always jumped out of 4 low if I don't bungee it to the dash. I've replaced the detent springs & balls (one was missing all together) but that didn't help. Recently it got hard to find 2 hi. I used to have a floor mounted 3 speed shifter (now running NP435), so I can pull a piece of sheet metal & see the D20 shift rails. I easily can put it into all the gears with a little help from a pry bar. The J-shifter seems sloppy & I think is the problem, its not pushing the shift rails far enough forward and back. I'm hoping that if the tcase is fully engaged, maybe even the 4 low will stay in gear.
I want to put a QUICK & CHEAP twin stick in, because I intend on loosing the D20 for an Atlas someday. But funds are limited and someday is not today. I found a fairly complex DIY twin stick on CB.com:
http://classicbroncos.com/tech/fabricat ... ord-bronco
My first thought, before doing any reading, was that a twin stick wasn't going to be that complicated. I thought about just welding new shift levers to the shift rail tabs. Am I way off base? Would it be too hard to shift gears without the pivot created in the above article?
Any advice or pics of more simple set ups, I'm not concerned with being tricked out or super stylish, just want it to work. Function before fashion. If you saw the rest of my truck, you'd understand.
Chad
Wed Jul 06, 2011 12:41 pm
Post Re: D20, J-pattern DIY twin stick question
The J shifters suck. The first best thing I did was to get rid of it and go with twins. You will need the pivot points but it wouldn't be difficult to fab one up.
Wed Jul 06, 2011 1:21 pm
Cool thanks. If anyone has any pics or links of other set ups I'd love to see them before I break into this project.
Chad
Wed Jul 06, 2011 3:12 pm
I just edited the link in the 1st post, it wasn't right.
Chad
Wed Jul 06, 2011 3:55 pm
BC's is pretty simple:
more google action:
http://www2.broncofix.com/viewtopic.php?t=3408
Wed Jul 06, 2011 5:07 pm
Could be a fun basic fab work tech class.
Wed Jul 06, 2011 6:34 pm
I just ordered one the other day from Toms. Tired of the J shifter issues. Gunni they look pretty straight forward to make. Maybe when I get mine I'll post up some info to fab one. Viper probably has the plans drawn up in his head already.
Wed Jul 06, 2011 7:10 pm
It takes about 10 minutes with a cut saw if the TC is out of the vehicle. Here is a spare C4 and D20 I have that I twin sticked.
Wed Jul 06, 2011 7:27 pm
Wed Jul 06, 2011 7:32 pm
Wed Jul 06, 2011 7:33 pm
Wed Jul 06, 2011 7:48 pm
Wed Jul 06, 2011 9:51 pm
Thu Jul 07, 2011 8:22 am
Thu Jul 07, 2011 8:29 am
Thu Jul 07, 2011 12:59 pm
Chad, I was the same way. Actually wanted to build my own stuff, but never had the tools. I now have a couple grinders and a welder and make a lot of things with those two items. And I enjoy the heck out of it! Finding time is the tough part!
Thu Jul 07, 2011 1:56 pm
Thanks for the help. I got it 90% done today. Unfortunately, there has been little or no work for us lately, so I've been spending the days working on the Bronco.
I'll post up some pics soon, but its a total rip-off of 76fordbronco's. I'm going to drive it this weekend & test it out, see if it'll stay in 4-lo better. Next week I'll paint it, and add some knobs. Gotta order a twin stick boot.
Chad
Fri Jul 08, 2011 6:35 pm
Sat Jul 09, 2011 6:51 am
I'll keep my eyes on it, thanks. Perfect "package" deal. I've gotta order a new rear shock mount, so I was going to place an order with Jeff's on Monday. I really need to fix my rear shock before Ouray, its not a big deal, but I've been running around with 1 rear shock for almost a month. Hopefully I'll find something at the hardware, or welding shop for a set of knobs. I'm not down for a $50+ set of billet knobs, Jeff's only option. That is the least of my concerns, though.
Chad
Sat Jul 09, 2011 8:49 am
How did this turn out? I was thinking about doing the same to mine here soon. I read the DIY on CB.com and it looked pretty complex but if you found a quicker/easier way to swap out the J-shifter I'd love to see it.
Thu Aug 18, 2011 3:28 pm
Sorry I didn't get pics before I buttoned it up, but really I just copied 76fordbronco's pics above. My pictures wouldn't add much. It works great, the t-case hasn't popped out of any gear since. I think the old j shifter was wiped out and/or the body was pushing the shifter out of gear.
Let me know if you want pics of the pieces apart, I can easily remove the shifters tomorrow & snap some pics. Forget what you read at CB.com, that is for a T shifter & complicated by T shift standards. It was very easy, I even found 2 black knobs at a hardware store for like $6.00 each. They had 1/2" course thread inserts.
Chad
Thu Aug 18, 2011 4:23 pm
Users browsing this forum: No registered users and 23 guests
33,010,177 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
