It is currently Sat Nov 23, 2024 3:14 pm
Now: The Old School Super Duty
I guess this is a bit of a feeler/good to know. Wondering if anyone has a gooseneck trailer, 20' minimum and rated at 5k or larger, that they would be willing to lend out.
I'm eyeballing a 78 F250 Supercab long bed in Idaho and I don't quite have the confidence in my 20' bumper pull to handle the task.
Because I know there will be questions... 1. Buy 73-79 Supercab long bed 2. Sell '03 F250 3. Install 7.3 Powerstroke in 73-79 F250 4. Drive and smile
Of course, at the rate I accomplish things, this will all be complete exactly one day before the apocalypse.
Sun Apr 26, 2015 9:06 pm |
Re: 20'+ gooseneck to borrow?
So one day of driving & smiling, that's worth it!
Sun Apr 26, 2015 9:16 pm |
Sun Apr 26, 2015 9:22 pm |
Sun Apr 26, 2015 9:48 pm |
You're looking at it all wrong. Do it roadkill style. Drive the '03 up, pull the engine and swap it into the '78, drive the '78 back.
Sun Apr 26, 2015 9:52 pm |
Sun Apr 26, 2015 10:01 pm |
Moab Mike
Your truck and trailer would have no problems!
Sun Apr 26, 2015 10:56 pm |
My hitch is rated at 5k. My trailer weighs 3k. Curb weight of this bad boy is somewhere between 4500-6k, depending on who you ask.
Sun Apr 26, 2015 11:15 pm |
Get a Weight distribution/sway control hitch and go get it done.
Mon Apr 27, 2015 6:03 am |
sykanr0ng
Mon Apr 27, 2015 9:38 am |
Find another trans and swap it there. Drive it home. I have a decent trans jack you can borrow
Mon Apr 27, 2015 9:47 am |
Flat tow it? Your SD outweighs it by enough.
Mon Apr 27, 2015 9:57 am |
I know you guys are trying to help...but this is likely a problem that doesn't need a solution.
1) A weight distribution hitch is a great idea. For a one time use, not so much. I'm already looking at $600 in fuel to make the 2300 mile journey to pick this thing up, not to mention 32 hours of driving accoring to the Googs. Add on to that the installation and wait time for said hitch. Yes, it will fit an older truck as the set up is designed from the hitch back to the trailer. However, I am not anticipating needing to pull this size of load again anytime soon. And when/if that occurs, I hope to have my hitch situation rectified on the trailer end of things.
2) As tempting as it is to swap in a new trans and drive it home, I do not plan to keep the current drivetrain in it for long. So, buying ANOTHER trans that I will have/need to sell down the road isn't cool. Plus, 32 hour round trip now gets longer with the R&R time for said transmission. Also, I do not know how long this truck has been off the road, so driving it 1100+ miles back to Colorado from Idaho doesn't sound that fun when you have a job to be at on Monday.
3) Flat towing is another option. Not really looking to spend money on a tow bar. Not really looking to screw up a decent stock bumper to install said tow bar. Not looking to have said tow bar around the garage tripping me up after I get home.
In all honesty, there's only a 50%, at best, chance that this will happen. As I said in the original post though, it would be nice to know that a goosey is available should I need it in the future. So, if one isn't available now, it just gives me an excuse to not be disappointed at not being able to do this now versus later.
Now, if T.O. happened to leave my yard, options would certainly open up immensely with regard to this. But, I still don't have it where I want it before it goes up for sale.
Mon Apr 27, 2015 10:43 am |
Dirtheadz
How about getting a shipping quote from a transporter?
Mon Apr 27, 2015 12:21 pm |
Mon Apr 27, 2015 12:25 pm |
Mr. Lav
Joined: Sun Apr 17, 2011 11:33 am Posts: 200 Location: yoder, colorado
Hey Zack give me a call or pm me
Mon Apr 27, 2015 12:31 pm |
Sent you a PM Alex.
For the masses: As long as we're taking this train all over the neighborhood, what auto trans would YOU run behind a 12V Cummins?
Mon Apr 27, 2015 1:07 pm |
Found a trailer. :) Here's the truck. And I might have already found a buyer for the Super Duty. Which means a) I've got an awesome truck, b) I've severely under priced it, or c) I found a very uneducated buyer. No idea which it might be.
Mon Apr 27, 2015 2:41 pm |
Mon Apr 27, 2015 4:43 pm |
Mon Apr 27, 2015 5:11 pm |
You've got a family, start looking for that needle in the haystack crew cab...
And as much as I hate to say it, perhaps a 6BT would be an easier swap??
Tue Apr 28, 2015 5:49 am |
Tue Apr 28, 2015 6:44 am |
Re: Now: The Old School Super Duty
Thought I would go ahead and get this out of the classifieds.
Tue Apr 28, 2015 7:02 am |
Here's a gas engine you can get locally, (Greeley) drive home, then tear it apart??? http://fortcollins.craigslist.org/cto/4968559177.htmlTo new for you?
Tue Apr 28, 2015 9:02 am |
Tue Apr 28, 2015 9:05 am |
"INJECTOR TIP BROKE OFF TODAY. TAKING OFFERS. RUNS BUT VERY POOR" http://denver.craigslist.org/cto/4991684670.html
Tue Apr 28, 2015 9:07 am |
JGZ
There's a red one running around up here in Lakewood that's done up just the way your talking about.That thing is badass.I'll try to get a pick next time I see it.
Tue Apr 28, 2015 9:10 am |
Ahhh...'73-79....Gotcha!
Tue Apr 28, 2015 9:11 am |
Tue Apr 28, 2015 10:42 am |
Getting warmer!!
Tue Apr 28, 2015 10:46 am |
