www.ColoradoClassicBroncos.com - View topic - 7.3L diesel advice
It is currently Sat Nov 23, 2024 4:21 am
Reply to topic  [ 351 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12  Next
 7.3L diesel advice
Post Re: 7.3L diesel advice
Mon Nov 09, 2015 9:09 pm
Im sure you are right. Just my misconception. Im looking forward to seeing how the truck starts and drives with new injectors. Im not looking forward to the parts bill.
Mon Nov 09, 2015 9:53 pm
Change to synthetic it will make a world of difference.
Mon Nov 09, 2015 10:48 pm
Mon Nov 09, 2015 10:59 pm
I hope they work as well as they look now. Sorry. No before shots.
Also, if there is a hell I hope bin Laden is down there hard at work installing pink o-rings on 7.3 injectors. My thumbs are killing me.
Mon Nov 09, 2015 11:27 pm
Mon Nov 09, 2015 11:42 pm
Mon Nov 09, 2015 11:57 pm
I bit the bullet and swapped my injectors for stage 1's. I was planning on holding out for a while but with a road trip on the horizon I just went for it. I was going to get full force diesel stage1's from Riff Raff but I really wanted the Hydra Chip and Clay does not sell it. I decided to get the injectors straight from Full Force along with the PHP hydra chip. Also, I had 12 cores and Full Force gave me additional credit for my extra cores, Injectors are the same $ either place and they are the same product. I can tell you the truck feels 100% different. Before Installing the chip, I ran it with the stock tune and new injectors and it was a significant improvement over my stockers with 235K on them. My only complaint with the hydra chip is it pumps out more smoke than I would like for daily driving but after talking with Full Force, they are setting me up with additional tunes that will be more friendly for the people driving next to me. The Hydra chip is a 17 position chip so I can keep my ridiculous 140HP smoke cloud tire eating tune for screwing around an still have good usable tunes such as high idle, towing tunes and DD tunes. The other nice thing about the hydra chip is that you can download the tunes or have them emailed to you. If I want to change the tunes on the chip, I can do it from a laptop computer sitting in the driver seat. I"m very interested in how its going to tow now, Improved towing was the goal with all of my modifications. If your on the fence about stock injector reman injectors vs stage 1's, I would invite you to test drive mine. I think the few extra dollars spent is $ well spent
Tue Nov 10, 2015 1:10 am
Tue Nov 10, 2015 1:51 am
Tue Nov 10, 2015 6:39 am
16* air temp this morning, 30* engine oil temp, synthetic oil, only one injector sounded bad for the buzz test.
Glow plugs cycled for full 2 minutes & rested for the time it took to connect & do the buzz test (probably 4 minutes total), then tried to start it. Truck didn't want to start. Cycled the glow plugs for 30 seconds & it started up easily.
The buzz test alone proves the 5-40 synthetic is worth for cold weather starts.
The rest of the week, it will be plugged in for early morning departures. I"m confident it won't have trouble starting in the afternoon. It probably won't sit ALL day. I usually return to the truck & maybe move it around lunch or early afternoon.
Tue Nov 10, 2015 1:11 pm
Tue Nov 10, 2015 7:00 pm
Thu Nov 12, 2015 3:42 am
Last night I completed the swap of the re-ringed injectors. Rather than try to start it with my frozen hands, i plugged in the block Heater and called it a night. This morning it fired on the second crank and idled as smooth as could be. Took it out on a 50 mile run to blow the air out of the lines and it performed better than before.
The true test will be tomorrow with the cold start.
Sat Dec 12, 2015 2:26 pm
I assume that you don't need the torque wrench then? Sorry I had to work today till 5:40, I hadn't heard from you and I'm currently driving my brother in laws tiny Chevy spark, wasn't sure if it'd make it to your house safely.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Sun Dec 13, 2015 12:12 am
Sun Dec 13, 2015 12:27 am
Third attempt to start and it fired right up. Previous two might have been residual air in the oil rails or the position of the tuner.
I drove it yesterday and parked it around 1:30. Oil temp showed 26*F before I made the first crank attempt. No block heater last night.
I think I finally solved my cold start issue.
Sun Dec 13, 2015 10:46 am
Nice!
Sun Dec 13, 2015 11:33 am
Congrats! Should make this winter a little easier.
Sun Dec 13, 2015 12:00 pm
I'm towing the 73 to Missouri next week. That will be a good test to see how much difference the injectors make.
Sun Dec 13, 2015 12:34 pm
Sun Dec 13, 2015 12:49 pm
Sun Dec 13, 2015 1:11 pm
17* this morning and the truck fired right up after 0:30 of glow plugs.
Wish I had replaced those damn injectors years ago.
Tue Dec 15, 2015 1:16 pm
Good work! Feels good!
Wed Dec 16, 2015 8:49 am
Here is one. I have a 97 7.3 and when I add a load to the truck it doesn't pull worth a crap but then I run it by its self and it runs great. I have taken it to 3 shops and they all said that it is fine no codes nor any problems. I am confused. I have a 95 with the same engine and when loaded it will pull at 55-60 mph up hill. The 97 drops down to 30 mph with same load going up the same hill.
What could be causing this problem ? Any ideas ?
Wed Dec 16, 2015 10:17 am
Wed Dec 16, 2015 3:18 pm
You probably have a manifold leaking or up pipes so you have loss of ex pressure so it's not spooling your turbo very well or your hpop is going out and dropping pressure when your trying to give er more throttle to go up the hill if you guys have any questions or work that needs done I can do it I've been working on powerstrokes for along time I have 2 97s and a 96 one 97 is a very built sled pull truck
Wed Dec 16, 2015 5:40 pm
Wed Dec 16, 2015 8:01 pm
Yes. You've likely got the leaky up pipes that Justin mentioned. Your exhaust pushing the wheel on your turbo helping to shove air into the cylinders. If your up pipes leak, it's not getting enough exhaust to help force air.
This is probably only one of a few issues you are experiencing, but a good place to start.
Wed Dec 16, 2015 8:13 pm
well my luck on a good running 7.3 I think is over. Lost what I believe is the turbo. wont know until I can tear it out and rip it apart.
Wed Dec 23, 2015 7:05 pm
32,966,353 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
