casadejohnson wrote:Almost forgot about my latest power stroke junkyard score. I picked up a set of injectors from an 03 power stroke. I know my current injectors are single shots and the 03's are split shots but they are significantly larger than what I have now. So, are they worth swapping in? I have read mixed reviews on running split shots in an OBS. Rob, if your seeing this you probably know the answer to this one. I got them thinking they could be used as cores or I could just sell them to help finance getting something else. I also got 4 early 99 split shots ( Someone beat me to the driver side Bank ) and a spare Injection control module. I read about having work done to the injection control module to get some power gains. Any one know if that is a worth while mod? I don't want a race truck, I want to pull my 5th wheel up I-70 at a speed somewhat close to the speed limit.
If you find the 03s provide no significant advantage, let me know and we can work something out. I suspect some of my cold start issues stem from stiction inside my injectors due to poor PO PM.
