www.ColoradoClassicBroncos.com - View topic - My 76 so far, new pics
It is currently Sat Sep 28, 2024 5:28 pm
Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Post My 76 so far, new pics
I can only do two photos at a time i guess.
What did you learn?
Wed Feb 22, 2012 3:16 pm
Post Re: My 76 so far
More
What did you learn?
Wed Feb 22, 2012 3:19 pm
More
What did you learn?
Wed Feb 22, 2012 3:21 pm
Thats all I have for now. I have added a winch and that's about it. It was in rough shape when I got it and I have repaired the passenger floor and sprayed bed liner and those seats are out of an Audi and the power works. It used to be white and orange and probably a few other colors that I have found on it. Did disc brake conversion and made tie rods and drag link. Replaced the awesome old school red Rancho lift with a new WH kit. 3.5 in the back and 4.5 in the front. Twin sticks and new transmission.
What did you learn?
Wed Feb 22, 2012 3:28 pm
Diggin the murdered out look. Gonna keep it that way? Good lookin rig!
BTW the photos are limited to 2/post to encourage folks to use external hosting sites like photobucket.com etc. I believe the pics on the site will be going away some time in the near future.
Wed Feb 22, 2012 4:06 pm
Great looking Bronco, man. Love the flat black, power seat (whoa!), nice size lift, tires and wheel, great bumpers too. Real cool look with everything blacked out. Thanks for posting up some pics.
Is that a Stone Crusher Steering?
Wed Feb 22, 2012 4:51 pm
I made the steering myself. Big difference from before. I would love some new wheels and get rid of the super swampers as well. The PO had swapped drum brakes on it before I got it and had to convert it back.
What did you learn?
Wed Feb 22, 2012 5:18 pm
Very nice!! Good job on the steering setup. You should produce them for the club! "Lilaized Steering". :)
Wed Feb 22, 2012 7:32 pm
It actually was not that expensive to make. Heim joints and welded bunts to DOM tubing. I will help anyone make a set.
What did you learn?
Wed Feb 22, 2012 9:53 pm
Nice looking rig. I've always wondered how a Bronco would look murdered out. Zillacon helped me make a similar tie rod setup, only difference is that I used Chevy 1 ton tie rod ends. I'm pretty sure I could jack up the truck on it in a pinch.
Wed Feb 22, 2012 10:27 pm
I would love that steering setup - I may take ya up on fabbing up a set. May be a tech class for this spring.
Wed Feb 22, 2012 11:29 pm
The tires look to be in good condition. I would think you could sell the set and put a huge dent into something you'd like more...
Thu Feb 23, 2012 8:44 am
Thu Feb 23, 2012 8:56 am
Thu Feb 23, 2012 9:00 am
Thu Feb 23, 2012 10:52 am
I want the heim system like lila76. I tried to get Stone Crusher to become a Vendor on the site a month ago and never followed through. I would love to make my own for less money and do it myself. Name the time and place for the tech class and I will be there.
Thu Feb 23, 2012 1:34 pm
Thu Feb 23, 2012 1:39 pm
A couple of other considerations with heims vs. TREs:
1. If you move the tie rod over the knuckles you have to stack the heims on the passenger's side on top of each other. This creates a fair amount of leverage due to the longish bolt required, increasing the chance of failure and the slop that Zilla mentioned.
2. Some installations see increased bump steer since the drag link is connected at the knuckle rather than partway down the tie rod as in the stock setup. This isn't a huge deal, but can be annoying and cause more wear and tear on the steering box, especially if the truck sees a decent amount of street use.
Thu Feb 23, 2012 2:07 pm
I also am a firm believe that Chevy 1 ton TRE's are the way to go for steering. Mine has served me well for years. I have replacements that I need to put on since mine are getting sloppy, but far safer a HEIM. They also offer a little vibration isolation, which the heims do not.
This looks like a great kit to me:
http://www.ruffstuffspecialties.com/catalog/YLINK.html
Thu Feb 23, 2012 2:34 pm
I know that there have been a ot of discussions on heim setup or chevy knuckles. I have not noticed any bump steer as of yet. I figured that I would give this set up a try and so far I have had good results. It has definitely held up off road with no issues. I have also had it on the highway and no issues either. I used grade 8 hardware and I'm not too worried about any sheering of bolts. I also know there are different heim joints and I know mine are made with Kevlar and not nylon. Time and abuse on the rig will be the ultimate test but it is cheaper to buy a new heim joint than a rod end. I am primarily wanting to use the rig off road and for club meetings or a Sunday drive to the movies with the wife.
What did you learn?
Thu Feb 23, 2012 3:33 pm
I agree a steering build could be nice, iwas going to order a new steering set up but would perfer to do it in house. The flat black is great, i really like that you did the top and didnt leave it white! nice build!
Fri Mar 02, 2012 7:58 pm
Fri Mar 02, 2012 9:00 pm
Here's what I started with
What did you learn?
Thu Mar 08, 2012 9:41 am
More...
What did you learn?
Thu Mar 08, 2012 9:43 am
More
What did you learn?
Thu Mar 08, 2012 9:48 am
Fri Mar 09, 2012 2:27 pm
Post Re: My 76 so far, new pics
I got a little excited when I bought it because I thought it could have been a bronco or stroppe edition but I checked the vin on the glove box and no luck. A lot of orange on it though.
What did you learn?
Fri Mar 09, 2012 3:07 pm
was it an explorer?
Good looking ride. I think broncos look great in black. Im not a fan of "murdered out" vehicles but that does look good.
Fri Mar 09, 2012 7:27 pm
Wed Mar 14, 2012 4:11 am
Put my new/old soft top on and wheels. I like it a lot better than the old spray painted steel wheels. No more murdered out look
What did you learn?
Thu Mar 29, 2012 10:05 pm
32,366,715 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
