It is currently Mon Nov 25, 2024 12:35 am
1973 Stroppe Baja "Saved from the grave" TWICE
Re: 1973 Stroppe Baja
Git-r-dun!
Wed Jan 20, 2016 2:34 am |
Re: 1973 Stroppe Baja "Saved from the grave"
Nothing like a deadline to put your rear in gear.
Wed Jan 20, 2016 7:16 am |
Good luck with the title process.
Is it worth the rush to do it in Colorado? Is the MO process more difficult?
Wed Jan 20, 2016 8:30 am |
i was wondering about titling, so if its not running and driving I will not be able to switch the title over? I can wait but was thinking of getting the 72 in my name.. haven't done any research - lazy i know
Wed Jan 20, 2016 9:57 am |
Wed Jan 20, 2016 10:24 am |
Wed Jan 20, 2016 10:25 am |
Wed Jan 20, 2016 1:09 pm |
Wed Jan 20, 2016 1:46 pm |
Ok I have the title and its signed by the owner who sold it to my buddy. The date on the title is 2005 I think. I guess I will be paying some fees to get this thing titled in my name. The seller looked to be elderly and he filled in the mileage as the date. Hopefully can make this work as I don't think the guy is still around.
Thu Jan 21, 2016 11:43 am |
The max is $100 dollars in late fees + back taxes, so not too much.
Thu Jan 21, 2016 1:26 pm |
Well, we're already off to a bad start. Tonight I finished putting the builder 351 on the stand so I could do a quick check of it and figured out where it needed attention before reassembly. Turns out cylinder #3 had a ridge line of rust around halfway through the stroke. After some scrubbing and light scraping it's turning over by hand easily and the bore feels mostly smooth. So, I'm going to put it back together and see what sticks to the wall. It only has to RUN, not run well. That being said, I'll be prepared to pull my roller block as a replacement of necessary.
Also, an update on my already to tight timeline. The buyers requested the closing be moved to 3 days earlier. So, now the movers are likely coming a week earlier.
This project might be moving to the auto craft shop on Fort Carson before it even gets to my house.
Fri Jan 22, 2016 11:12 pm |
Sun Jan 24, 2016 8:36 am |
You have a lot of things to 'undo' to bring it back to stock.
I'm guessing you saw that one sold for $98k at a Mecum auction.
Sun Jan 24, 2016 10:31 am |
Sun Jan 24, 2016 11:13 am |
Did some things and stuff to the Free Fitty One. Are lifters supposed to be concave? This came out from the #3 cylinder intake valve. To say the cam is wiped would be generous. And out of the four spare parts cams I have here, all are rollers and will not work. So, I'll just drive on (with another lifter in the pocket) and keep my fingers crossed that I can make it through the inspection on 7 cylinders. Should be finished buttoning it up by Wednesday. Then I'll start into the pile o' C4.
Mon Jan 25, 2016 12:40 am |
Impounded by Colorado State Patrol on 22 April, 2016.
Fri Apr 22, 2016 12:11 pm |
Fri Apr 22, 2016 12:36 pm |
I guess worse case scenario... you have this build thread you can show the Po Po and get your axles, wheels, tires, engine, seats, etc. back?
(make sure you bill them for your shop time!)
Fri Apr 22, 2016 1:01 pm |
Fri Apr 22, 2016 2:24 pm |
What time is your Bail Hearing?
Fri Apr 22, 2016 2:42 pm |
Friday
Fri Apr 22, 2016 3:54 pm |
Update from Pueblo.
If the rightful owner of the Bronco does not claim it within 30 days, it will be transferred to the towing company for disposal/sale. If CSP values it at less than 350.00, it must be parted out or sold for scrap. If it values higher than 350.00, it can be sold and titled.
Thu May 05, 2016 1:19 pm |
So if it is valued less than 350, you can't get it titled again ?
Thu May 05, 2016 1:23 pm |
Thu May 05, 2016 1:39 pm |
Well, here's to hoping the value comes in at 351
Thu May 05, 2016 2:12 pm |
pgilbeau
Thu May 05, 2016 2:58 pm |
EFI Guy
Dude that sucks!
Having been a tow truck driver I can say that the CSP officer doing the evaluation will most likely accept input from the towing company (whether they want to resell or crush). And..as long as no one working at the towing company really wants it, they would most likely sell it to you if you express interest. Let them know you are interested in buying it back, but don't give them any idea of it's potential value. I'll be keeping my fingers crossed for ya!
Wed May 11, 2016 1:03 am |
sykanr0ng
Having seen rusted busted Broncos with no title on CL for $700 and gone in less than two days I would say it's a sure bet on $351+
Wed May 11, 2016 8:52 pm |
Fri Dec 09, 2016 12:58 pm |
Man, that is awesome!
Fri Dec 09, 2016 1:04 pm |
