It is currently Thu Nov 21, 2024 10:35 am
[ 7 posts ] |
Another hole in my head...
My name is Zack and I have a problem....
Sat Aug 27, 2016 4:43 pm |
Re: Another hole in my head...
I'm not sure you can save them all, but keep trying.
Sat Aug 27, 2016 5:57 pm |
Sat Aug 27, 2016 6:29 pm |
Colorado75bronc
You're definitely a fan of massive undertakings.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Mon Aug 29, 2016 9:29 pm |
Side mirror looks good...
Mon Aug 29, 2016 10:13 pm |
71 Broncman
I'd say that's not just another hole in your head, but also in your wallet as well. Being a fan of the old F trucks myself I say go for it. May want to think about a Cummins instead of a 5.8 plus 1 ton axles . I thought you were on the lookout for an F250 extended cab to do that to. How is the supply of parts vehicles in KC? After the scrapping frenzy when steel prices were high the availability around here is somewhat diminished. I did see a bumpside at ABC a couple of weeks ago that was fairly unmolested when I was there. Have fun with the project. Mark.
Tue Aug 30, 2016 7:17 am |
Tue Aug 30, 2016 9:20 am |
[ 7 posts ] |
