Who has a thread on installing the aod/4r70w
Found an awesome tech article out there on the internet and want to share it? Post it up here. Want to write your own tech article? Here's a place for it!
la hi
Post by la hi »
Who has the thread that describes the parts needed to put the 4r70w in the 66? I will remove the bell housing, NP 435, and adapter from the 351w all of which are out of the frame.
The body is off the frame and now is the time to make the change if i'm going to.
Re: Who has a thread on installing the aod/4r70w
Post by Kinder »
I donΓÇÖt think there is a thread just for the install, but plenty of folks have done it. Look at RoxΓÇÖs or ViperΓÇÖs build threads and see if they included the install in the posts.
http://classicbroncos.com/forums/showth ... p?t=167240
http://classicbroncos.com/forums/showth ... p?t=255139
I figured it out with these 2 threads. Pretty simple and straight forward swap. Will need to make new frame brackets for the cross member and modify the factory cross member. You'll need to pull the valve body out and change the shift lever. Also I'd recommend a minimum 1" body lift.
