www.ColoradoClassicBroncos.com - View topic - 95 F150 A/C not working
It is currently Thu Nov 21, 2024 10:19 am
Reply to topic  [ 10 posts ]
Post 95 F150 A/C not working
I’ve checked fuses and they are good. Blower works but it blows hot air. Anyone know what steps to take to check for why the A/C doesn’t work?
Fri Jun 08, 2018 1:31 pm
Post Re: 95 F150 A/C not working
No freon?
Fri Jun 08, 2018 1:36 pm
My guess is the compressor isn't turning. Could be clutch problem or no current to activate it. No current could be due to low pressure in the system. There is a pressure switch that will allow the compressor to run only if there is good pressure in the system. That switch could be bad or you may have a small leak.
Fri Jun 08, 2018 1:40 pm
Fri Jun 08, 2018 1:45 pm
hey Mike like they are saying you need to verify that you have a proper charge in the system a start working out from there.
Fri Jun 08, 2018 1:47 pm
Profile WWW
Fri Jun 08, 2018 1:53 pm
I've disconnected the lo pressure harness the turn the engine and a/c on and using a jumper wire (briefly) jumper the harness just to see if the compressor starts more than likely you have low Freon if the compressor starts. Good Luck
Vipers way is probably more sensible (but then I would have to put my :beer: down to use a multimeter)
Fri Jun 08, 2018 1:54 pm
Tried to jump the switch and I can’t tell if the compressor is kicking on. Air definitely wasn’t getting colder. My multi-meter is dead and I don’t have a battery for it so couldn’t check voltage to the switch.
Fri Jun 08, 2018 2:19 pm
Fri Jun 08, 2018 2:47 pm
You can see whether it is turning or not. The inside of the pulley does not rotate when A/C is not cycling.
Center of pulley should cycle on and off with A/C on.
I would guess you have a leak and have lost enough freon that the low pressure switch will not let the comp engage.
Sat Jun 09, 2018 8:07 pm
32,915,448 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
